brandonkick
I've recently "repaired" a laptop screen for someone.
They brought it to me because it would make this "ticking" noise and then the screen would go dark. Normally when a client says "ticking" I think the hard drive is ticking ( head crashing into the platter ) and that's the problem.
This time however it wasn't. The screen was dark but the ticking wasn't coming from the hard drive. I took a flashlight and shined in on the screen to see that indeed the picture was still there just not lit.
So I presume the inverter went bad. Ordered a new one off of ebay, popped it in and the same thing happened.
So now I figure it has to be the bulb. I ordered the bulb, swapped the new one in and now the screen "lights" but it's like the bulb isn't in "right" because the bottom inch or so is very bright and the rest of the screen, while perfectly visible, is considerably dimmer?
What did I do wrong? I think the layers aren't sandwiched together or something. I didn't have to remove all the layers to get this out, just the very top white plastic like sheet.
How can I fix this?
How can I fix this?
