EDIT: SOLVED - CPU was also fried, and yes, HDMI out should work at post
So I have a customer that bought the most expensive cup of coffee ever.. I told him that I don't like to do liquid damage anymore because it has a habit of frying out everything. He said he doesn't care how much it costs, he wants to fix it..
So I opened it up, coffee hit everything.. clearly shorted lots on the motherboard and keyboard, everything else that had coffee on it didn't look damaged..
CPU was covered by heatsink so no direct coffee damage. RAM didn't get any coffee on it.. Both hard drives had a little coffee, but just on the labels, not by the connectors.. USB board and card reader board both had a little coffee, as well as the connecting cables, again it looked like there was no actual damage. Same with the CD rom..
Ordered a replacement motherboard and keyboard, cleaned the hell out of everything else with alcohol and a brush. Reassembled everything, I'm getting no video.. The computer powers on, LEDs and fans come on, stays on for about 10 seconds, and restarts. Tried different ram, reseating all cables, minimal assembly(just dc jack and lcd cable(and then lcd cable plus the "3d cable" that goes to the monitor).. Same result.
If the battery is plugged in, the dc jack led is amber, if the battery isn't plugged in, it blinks white.. I think this is normal for this laptop..
I tried external video, but this laptop only has HDMI, no VGA.. I've never had a video issue on a laptop without VGA, so I don't know if you get HDMI out during post. HDMI gave me nothing even pressing the function button, and restarting it with HDMI plugged in.
The motherboard was direct from HP, and we tried RAM, so I'm thinking its either the CPU, LCD cable, or the LCD. I don't have a test cable, I have a test LED screen, but I'm not sure how this cable will react with a random screen, given it has a 3d cable too. (and I haven't opened up the top half to even look at the connectors to see if its the same). No test CPUs either..
So quick version -
1)Do CPUs fry with water damage commonly?
2)Is HDMI supposed to give external video during post?
I'm gonna open up the screen and see what my test LED does, but wondering if you guys had any other ideas...
So quick version -
