e2346437
The above process is probably not legal but as I have said before, I dont think MS is coming after me for anything like this.
Agreed. This thread is giving me a headache
Couple of comments.
I find that many Techs (?) do not bother to change the key to the correct one on the COA that is on the side of the computer case.
Even manufacturers don't always do it.
If I get time later, I will post instructions on changing the MSDN Retail Home or Pro from Retail to VLK or OEM and how to find out a key from the currently installed Windows.....
Just use a standard OEM CD
Is that the setupp.ini tweak?
So if I get the MSDN XP Retail from my school, I will be able to use it to reinstall XP on a customer's machine? How do I turn the disk into OEM?
They don't have to have the COA as long as I obtain the CD Key using a CD Key finder software?
Exactly what is one to do to stay legal?
I wouldn't recommend using your school's VLK, that is blatently wrong as you are using someone elses license to install it. There should also be no need for it as the key on the side should work perfectly fine.
Agreed. This thread is giving me a headache![]()
If there is no other option then idc. If they paid for a system that has XP Home then I'm gonna do whatever I can to reinstall that exact OS they paid for. Idc if the license is the same or not. As long as it's the same edition they have then it does not matter to me.
If I could reinstall with the VLK disk I have AND use their product key instead, then I would do that because it would be legal considering I'd be using the license they paid for. Problem is that I hear this will NOT work. OEM goes with OEM, Retail with Retail, and VLK with VLK.
If their are other options to reinstall XP when you don't have the recovery partition or the disks and can't get the disks, let me know.
