Still HP splash and spinner 2 hours on
he fact that the only drive being recognized is the USB drive
SSD is dead...INACCESSIBLE BOOT DEVICE.
Not necessarily. I had a similar situation a few weeks ago and somehow the drive had wiggled out of the socket and just needed to be reseated. I stand by my recommendation that the next logical step is to open the laptop and pull the drive.SSD is dead...
Sure, it's possible... but highly unlikely.and just needed to be reseated.
Disable.Any suggestions with regard to Optane?
Drivers made your disk appear in BIOS/UEFI? Magic indeedNo trace [in] BIOS [...] placed the driver on the bootable USB booted from the USB and like magic, they appeared.
From what I remember. I turned on my PC one day, and it would not boot. I went into the BIOS, and there were no drives. I did some research on another PC, and from that, I added the drivers for the SSDs onto a bootable USB (Ventoy) I still have the drivers at the root of this Ventoy drive. I booted from this Ventoy drive and don't remember if I clicked, moved, or copied anything. I remember it booted into Windows like nothing had happened and has been fine ever since.Drivers made your disk appear in BIOS/UEFI? Magic indeed![]()
You're overthinking it.
The SSD doesn't show up under the Windows installer itself. The drive that shows up is your USB flash drive. It's stupid, but the new Windows 11 installer shows the flash drive as a fixed disk. It's very possible that the drive is dead and just isn't showing up, but it's equally possible that the Windows 11 installer doesn't have the correct Intel RST driver and that's why it's not showing up. Enter the serial number into HP's website, download the Intel RST driver, extract it, put it on a second flash drive, then hit "add driver" (or whatever it says in the new Windows 11 installer), select the driver, then see if the internal SSD shows up. Windows 11 oftentimes doesn't have the storage driver for those crappy low end HP laptops built into the installer itself. I've had two of these in just in the last week. Very frustrating. If the new drive doesn't show up in the installer either, it's because the driver doesn't exist in the Windows 11 installer.Anyway, we're just waiting for a new SSD to arrive, then I'll install it.
Maybe you did flash the firmware of the SSD, which corrected the issue...I booted from this Ventoy drive
I don't know what to tell you. I see it at least once a week and not just on HPs. I've got an HP on my bench right now that won't recognize the SSD under the Windows 11 installer. I had to use the methods I outlined in my last post in order to get the SSD to show up.Second, I have never, ever, in all the Windows installs I have done, not had the drive onto which it is to be installed not be recognized in the Windows installer. Ever.
Seriously..Lie?Honestly, you don't need to tell me anything. You're reporting your experiences, and I'm reporting mine.
I will certainly keep what you've said in mind. But based on my own experiences I'm not "going to go there, first."
It seems that it's not all that infrequent that certain things happen far more frequently for some of us here than for others, and who can explain why that is. I'm not attempting to deny what others are saying, as they (you, in this case) have no reason to lie.
Seriously..Lie?
