Tech in SC
- South Carolina
HP Pavilion p7-1225 Desktop PC running Windows Home Premium 64-bit. My customer comes in one morning and the PC has rebooted (likely due to a Windows update). It is sitting at the login screen with the cursor flashing but the keyboard and mouse (both USB) do not work.
Further testing reveals that the USB functionality is dying during the boot process as its loading Windows. USB works outside of Windows (BIOS or Live Linux Distro). Safe Mode does the same as Normal Mode.
The PC has ONLY USB ports... no PS/2. So far, I haven't been able to get the USB ports to work or successfully get into a booted Windows environment. Here is what has been done so far:
* Ran system restore and rolled back to a restore point a few days before the problem. Only 4 points in which to choose, other 3 do not seem to 'restore'.
* Ran chkdsk, found issues (prob from the numerous improper shutdowns), fixed them, no luck.
* Boot to last known good config... no luck.
* Tried to boot to Windows 7 Home Premium DVD but it said it wasn't the right version (no OEM disc of course).
* Mounted the drive to another PC, used D7 to mount the registry and turned on RDP. RDP will prompt for credentials but just disappears when clicking 'connect'.
* Virus scan clean
* Installed USB add-on card... functions same as internal USB ports.
* Tried Dameware to install a remote access agent via network. It prompts for credentials and then craps out once the correct credentials are input.
* Put the HD in another PC to attempt access to Windows in Safe Mode but fails to boot.
I think thats everything. Let's see what some of you other techs can come up with. How do you get into a USB only PC when the USB ports do not work?
* Virus scan clean
