I've had it.....I just logged into a workstation to fix a failed GFI / Bitdefender install, ran D7, one of the first tools that I have set to run is CrystalDisk Info; it shows Reallocated Sectors on this PC.
Yesterday, I ran D7 / Crystal Disk on a different client machine, and it showed Current Pending Errors....GFI's check didn't catch ANYTHING wrong on either of the workstations!!!
I have / have had hundreds, probably close to 1,000 workstations on GFI, disk health check is ALWAYS enabled, it's only ever caught *maybe* 2 or 3 bad disks.
Clearly the check is useless...what is a good disk health check tool with alerting / monitoring features, that actually works??
I'd love to use CrystalDisk but it doesn't seem possible to customize the alerts to designate which PC it's coming from; you have to select a "to" and "from" email address, and that's all.... I could set it to write to the windows event log, then have GFI check for that, but that's a lot of work....
Would be great if I could somehow deploy it via GFI......
Thanks!
Thanks!
