ERD BSOD log deciphering
ell
Hi, I have a old HP tower here with random shutdown, (ofcourse not when I'm testing it) I found a few infections, nothing major and ran complete hardware scans overnight, everything clean. I booted to ERD and ran the crash analysis it points to hardware error, I'm a rookie at reading these things, I also ran bluescreenview and it listed this:
Dump File : Mini082212-01.dmp
Crash Time : 8/22/2012 9:23:27 PM
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x1000000a
Parameter 1 : 0x00000006
Parameter 2 : 0x000000ff
Parameter 3 : 0x00000000
Parameter 4 : 0x806f12b0
Caused By Driver : hal.dll
Caused By Address : hal.dll+22b0
File Description : Hardware Abstraction Layer DLL
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 5.1.2600.5512 (xpsp.080413-2111)
Processor : 32-bit
Computer Name :
Full Path : C:\WINDOWS\minidump\Mini082212-01.dmp
hal.dll hal.dll+22b0 0x806ef000 0x8070f300 0x00020300 0x4802517f 4/13/2008 1:31:27 PM Microsoft® Windows® Operating System Hardware Abstraction Layer DLL 5.1.2600.5512 (xpsp.080413-2111) Microsoft Corporation C:\WINDOWS\system32\hal.dll
ntoskrnl.exe ntoskrnl.exe+3721 0x804d7000 0x806ee500 0x00217500 0x4fa3d5b1 5/4/2012 8:12:17 AM Microsoft® Windows® Operating System NT Kernel & System 5.1.2600.6223 (xpsp_sp3_gdr.120504-1619) Microsoft Corporation C:\WINDOWS\system32\ntoskrnl.exe
USBPORT.SYS USBPORT.SYS+d13a 0xf71d0000 0xf71f3200 0x00023200 0x480254ce 4/13/2008 1:45:34 PM Microsoft® Windows® Operating System USB 1.1 & 2.0 Port Driver 5.1.2600.5512 (xpsp.080413-2108) Microsoft Corporation C:\WINDOWS\system32\drivers\USBPORT.SYS
The ERD report after debugging is attached, I appreciate any input on this!
The Stop 0a means
Typically due to a bad driver, or faulty or incompatible hardware or software. Technically, this error condition means that a kernel-mode process or driver tried to access a memory location to which it did not have permission, or at a kernel Interrupt ReQuest Level (IRQL) that was too high. (A kernel-mode process can access only other processes that have an IRQL lower than, or equal to, its own.)
I had one earlier this week, with the same stop code. It was the hard drive, going which was causing the bsod here.
I know you said, you have ran complete hardware scans, have you thoroughly checked the hard drive?
The Stop 0a means
Yes, I suspected the drive as well, ran complete tests with two prgms, guess I'll leave it run for a bit more, seems fine, I tweaked it from 77 to 30+ pocesses and disabled spybot cuz she already has AVG going, hate not being able to get it to crash.
Maybe they had something that was plugged into it that's not now?
Thats maybe what I'm thinking, the bluescreenview listed the usb driver as first in the chain, She has some random tablet program starting on boot, I'm going to ask her about that.
Have you tried a different (working) power supply?
Once had a similiar issue that was driving me crazy.
PSU "checked ok" with tester, but after replacement, it's now been fine for several years.
