enabler - re-enable stuff disabled by virus
AtYourService
CT
theres a blog i frequently check called ghacks that had a post about a program made in .net that re-enabled disabled reg entries that were caused by viruses etc , they touted the program as "portable" even though it had .net dependancies (they also offer a download with the .net files which come in at a whopping 50mb) We all know we can do the same things with a simple batch or vbs file. well i like assembly too and since i was complaining on the file size for something simple i decided to make the program
so here's the resulting 6.5kb file http://www.whatsmypass.com/enabler.exe
alls you basically do is open the program, check mark the things you want re-enabled (regedit,cmd prompt,taskmgr,folder option) and hit the enable button
let me know what you guys think
Can you make it so it determines if they are enabled/disabled in the first place. Checks in place or removed depending on current status ?
yea if i have time this weekend ill add some more code, wasnt sure if anyone was interested in a program like this so i just threw something together quick
I would use it as well.. I'm quite fond of your assembly skills/projects mate lol
Maybe once your all done move it to the Repair Tools of the Week ...
What OS are supported ?
added enable run box
and by accident i reversed the taskmanager code so it actually disabled task manager instead of enabled :eek:
so redownload the newer version at same link
still a work in progress , besides the stuff enabled already anything else i should add
@iisjman07 i commented on that post, i forgot all about it
was bored today so i added loading icons from shell32.dll to the form
you can redownload from the same link http://www.whatsmypass.com/enabler.exe
still debating on adding if the key is there to checkmark the boxes
maybe if i got time this week i can add the code
has anyone had problems with it yet
this didnt before, but is not being picked up by Sophos as
File "C:\Documents and Settings\...\Local Settings\Temporary Internet Files\Content.IE5\3A2LANN1\enabler[1].exe" belongs to virus/spyware 'Mal/Packer'.
How shall I get around this? If i place on my USB toolkit, it will get removed at first scan?
Here are a few apps to look at if you want to get some ideas for the code/ui. http://sourceforge.net/search/?type_of_search=soft&words=virus+registry
My Tevics script also re-enables stuff, but it doesn't have nitty-gritty options though, just a 'Reset-the-registry' function because I don't see the need (for a technician) to have to go through and pick what items should be enabled.
Why does it matter if task-manager and the run box were disabled but not the registry editing? Just turn it all on. ;)
Great tool so far, thanks! One thing that I have not found on any tools of this type is the option to re-enable the taskbar. I have had a hell of a time getting the stinking taskbar back sometimes. Is that something that can be added? I have no programming skills whatsoever so I don't even know if this is a reasonable request. Thanks again, this looks to be the start of a great tool!
http://www.kellys-korner-xp.com/regs_edits/nodesktop.reg
yea av's never liked FSG because virus writers used it to compress the .exes all the time
it had greater compression than upx though :/
i compressed it with upx now its 8kb and i made it start with checkboxes checked ,and icons to let you know if the function failed
and added manifest to prompt for admin rights on vista and win7
Cool, thanks. It kinda reminds me of Taskbar Replair Plus which is partially free, maybe look there for more ideas on fixes that can be added so we all benefit from a better app, thanks again! :cool:
