loaner
- Kosciusko, Ms. USA
Picked up Dell gx260...customer said "doesn't do anything".
hooked up and booted up...got the "system battery voltage low" message. F1to continue or F2 to enter setup. hit F1 and computer booted fine. i was able to do anything and go anywhere until the battery hit bottom and system froze. shut system down...waited a few minutes and booted again the same way.
picked up a couple of new batteries from walmart, replaced and i get nothing. fans will not work, nothing works. the original battery is panasonic cr2032 3v.
pulled batteries from my gaming rig(which is the exact same) and another computer i had lying around and same thing with those batteries, NOTHING.
I replace the original battery and it will boot right up with the "system battery low" error. hit f1 and boots right up...
power supply, ram, ect all tested working fine. my only other suggestion is replacing the motherboard, but i'm not completely sure about that. the internet is lousy with dell motherboard problems and suggestions for solving this problem...
I've cleared bios error log, plugged computer straight into mains instead of surge protector.
also tried resetting computer three times to allow it to recognize the new battery,,, blah blah....
nothing seams to work on this thing except the original battery.
i'm at my wits end on this thing and any help would be appreciated.
by the way...the original battery tests at only .77 volts...all the other batteries test well over from 2.6v thru 2.97v.
...goss
...goss
