Mainstay
Hi All,
I used dd_rescue on a damaged drive about 2 years ago and it worked amazingly.
The downside is that I was so freaked out about the interface and the procedures that I basically stopped after that first attempt. There is no way I could safely train a staff member to perform these recoveries and still sleep at night.
I understand ddrescue is superior to dd_rescue and that there is even a GUI that helps things along.
First: is ddresuce + gui just as good? Maybe an expert could tweak it further with CLI but will this hit 95% of the scenarios you encounter?
Second: What OS do you run out of and / or recommend?
Definitely not a Linux guy, so hopefully someone says, "ya, Ubuntu with the repository installed will get you all you need."
Thanks all!
--Matthew
(btw: read the other posts on this and no-one mentioned exactly what flavor of Linux they were using)
Thanks all!
--Matthew
