Can no longer downgrade from Office 2016 to 2013?
HCHTech
Pittsburgh, PA - USA
I have had to do this a few times in the past. Initially, I would call MS support, jump through the hoops, explain my situation (usually some LOB software not compatible) and they would issue me a 2013 key and download link.
Then, somewhere along the way, it became possible to do this without calling support. Log in to the MS account you are registering Office with, click on Install, advanced options or something like that, and you could choose your "preferred version". You picked 2013 and it downloaded and would activate just fine.
I think it's been maybe 6 months since I did this last.
So anyway, I tried to do it today - I have a lawfirm that is delaying their upgrade of Timeslips until EOY. Their version (2014 or 2015, I think) isn't compatible with Office 2016. It works, but you can't do the things that use hooks to Outlook (email this report, etc.).
First I tried to do the download thing - that option is no longer presented. The only choice offered is to download 2016. Then, I tried a live chat - after I finally got an agent to explain the situation to, they said you could not downgrade. There was no choice but to install 2016. He did say that you could purchase 2013 directly from Microsoft if you called the sales support, but you couldn't downgrade an already-purchased 2016.
This was only one person, so I don't know if that's the real answer, but it seems like the policy has changed. Head's up.
I had found a way to do that with Office 365 about a year ago. It may have changed.
What kind of license are you using? Office 365, retail, open?
I used this about a month ago and it still worked. Use the Custom ODT tool, which is sort of a PITA and they should just have a stinkin' GUI for it.
<!-- USEFUL INFO:-->
_________________
Sample Config:
<Configuration>
<Add SourcePath="" OfficeClientEdition="64" >
<Product ID="O365ProPlusRetail">
<Language ID="en-us" />
<ExcludeApp ID="Access" />
<ExcludeApp ID="Groove" />
<ExcludeApp ID="InfoPath" />
<ExcludeApp ID="Lync" />
<ExcludeApp ID="OneNote" />
<ExcludeApp ID="PowerPoint" />
<ExcludeApp ID="Publisher" />
<ExcludeApp ID="SharePointDesigner" />
</Product>
</Add>
</Configuration>
_________________
ExcludeApp IDs
Access
Excel
Groove
InfoPath
Lync
OneNote
Outlook
PowerPoint
Project
Publisher
SharePointDesigner
Visio
Word
___________________
ProductIDs
ProPlusRetail
ProfessionalRetail
HomeStudentRetail
HomeBusinessRetail
O365ProPlusRetail
O365HomePremRetail
O365BusinessRetail
O365SmallBusPremRetail
VisioProRetail
ProjectProRetail
SPDRetail
TO INSTALL:
1) Create a folder named ODT (or anything you choose) on
the C:\ and place setup.exe and configuration.xml into the folder.
2) Hold shift, right click, and choose "Command line here" or CMD and CD to that directory
3) run, without quotes: "setup.exe /download configuration.xml" to download the necessary files
4) run, without quotes: "setup.exe /configure configuration.xml" to install the custom apps.
<Configuration>
<Add OfficeClientEdition="64" Branch="Current">
<Language ID="en-us"/>
<ExcludeApp ID="Access"/>
<ExcludeApp ID="Groove"/>
<ExcludeApp ID="Lync"/>
<ExcludeApp ID="PowerPoint"/>
<ExcludeApp ID="Publisher"/>
<ExcludeApp ID="Outlook"/>
<ExcludeApp ID="OneNote"/>
</Product>
</Add>
</Configuration>
