Bluetooth still broken in windows 10
Galdorf
Ontario, Canada
After months of waiting for Microsoft to fix Bluetooth in windows 10 i ended up going back to wired headset for my personal computer i have 2 nice pairs of Bluetooth head sets one ultra-light ear buds and other over the ear with loads of features as well as noise cancelling can't believe it is taking this this long to fix major issues in windows 10 really thinking about going to Linux.....
I have not had a single issue with Bluetooth in Windows 10.
What is your version and build, and have you updated each and every device's device drivers?
I have no issue with BT. On both of my Lenovo Idea Pads or my XPS laptops BT works flawlessly and my Idea Pads are realtek. What version is you BT on the headsets and the machine? BT 4.* is backwards compatible but if your machine is BT 3.* and your headsets are 4.*, it wont work or work correctly. Found that out on a clients HP laptop.
So, shouldn't we be getting mad at Realtek? Like the Windows site says, Realtek needs to release drivers. That's not MS's job to make drivers for 3rd party hardware.
I just tried my Wife's Lenovo ideapad (Realtek), seems to work.
Depends on what chipset mine is quite old and built into the motherboard tried removing drivers and re-installing no luck i did buy a BlueSoleil bluetooth dongle now i have no issues with constant cutouts sitting right next to it and is BT4.
Did not have any issues till i upgraded the feature update to current don't feel like going back just for bluetooth new adapter has 2x range seems sound is better as well.
This isn't necessarily Realtek's fault either. They license their chips for others to build hardware, and those others often customize things such that the reference drivers won't work.
If anything Realtek should be more selective in who it sells its crap to. Because there is no end of gigabit NICs out there with their name on it that won't push more than 200mbit.
That may be true, however, Realtek still produces the core drivers which are then distributed to the 4th parties for their customization. The drivers are IP, so it's not up to "some weird brand" to produce drivers - other than to customize them.
OP - What Realtek chipset are we working with here? Maybe it's simply too old to receive new drivers. In which case, if we have a 10-year old BT receiver... well.. makes it that much harder to blame Realtek or MS.. or whomever.
Yeah, but that's not what's at play here right?
It's not as if that hardware ID lacks a driver it has one... just a broken one. If there's a newer driver being inappropriately applied to older hardware, that's also a fault in the driver.
I'm not sure the circumstances, TBH. I would imagine that he has a driver installed, likely an older one(Which could be the newest!) that worked with prior versions of Windows, but no longer works in the newest "cutting edge" Version of Windows 10.
Microsoft has been actively working towards denying direct IO and Kernel access to drivers - among a host of other low-level "tools"/API's that drivers would traditionally use (In the legitimate name of security). APC's(Asynchronous Procedure Calls) are a good example, wherein a driver could be compromised and potentially allocate and insert code into a privileged process. This is the essence of the DOUBLEPULSAR backdoor. How Microsoft found a Huawei driver that opened systems to attack
If a new, but incorrect driver is being installed it can mean a few things.
1. Microsoft could be to blame if the Windows Update Catalog database is incorrect.
2. 4th party could be to blame if their customization interferes with the new driver, or rather, the "stock" driver no longer works with the custom design they implemented. Trust me, Hardware ID's are not 'changed' as often as you would think... a 4th party could simply have kept the original Realtek HID, as it was shipped to them. Registering and getting a driver or HID accepted by MS is a grueling and potentially expensive process - Those "one-hung-low" brands will often skip that.
3. If it is indeed a new driver and it applies to the 'older' hardware, but doesn't work:
a. The driver is applying correctly, to the correct hardware ID's, but simply doesn't work or is flawed in some other way (eg. Rqd. direct kernel or IO access)
b. The driver contains a look-up for incorrect hardware, as you allude to. (This would be pretty rare though)
I would try pulling the hard drive temporarily and installing a blank drive. Do a clean install of Windows 10 and all updates. Then try using the bluetooth.
I have a suspicion bluetooth would now work fine. If it does it's time to FABS it and N&P.
Found a fix/work around to get the original adapter working while it is quite old i will be using dongle as sound quality and range is much better and its not realtek and has more features.
https://www.bleepingcomputer.com/ne...-windows-10-1909-realtek-driver-update-block/
My home computer has loads of features that work from bluetooth on mobile app i can turn on or off my computer, see all temps, change fan speeds, change overclocking profiles also get alerts on over heating.
