thecomputerguy
Got a client using AutoCAD with 7 designers and the have been having issues for awhile because they are storing all their drawings on Dropbox and it's creating conflicted copy's everywhere and not syncing properly, and designers are opening the same drawing and overwriting each other, drawings are getting damaged.... It's a nightmare, mainly because there is no file lockout.
Client is currently paying Dropbox $2600 per year for 15 users. Dropbox is an incorrect product for this application.
My plan is to split their data between whatever new location we choose, and O365 Teams/SP for all the other stuff that isn't AutoCAD (Word, Excel, PDF etc.) then dump Dropbox.
They currently use remote access software because they are too cheap to supply their employees with decent Laptops to work from home.
So, in my research
Egnyte:
Egnyte keeps coming up as a somewhat affordable option. I assume this is to be used with their Cloud Drive App which allows you to Map a Drive letter to your shared data directly so there is no syncing going on.
- This keeps us cloud based at a reasonable cost, and adds a mapped drive for file lockout
$3600 per year for 10 users & 2TB storage
Autodesk Vault:
Not much research here, looks to be very expensive at around $10k per year, and probably more than what they need but I'm open to suggestions
Dell Server:
Move back to an in-house Dell Server running 2022 with as much local storage as we can afford for a one-time cost of $8k-$10k. Probably the worst option.
-Also this makes us go backwards into having to store and maintain physical hardware.
Synology NAS + VPN:
Does a NAS work well in this application with AutoCAD? I know I can build out a pretty beefy NAS with 20TB of storage for a relatively cheap one-time cost then VPN them into the network and Map a Drive. They would probably need to upgrade their internet as they are on something like a 50down/50up satellite connection.
I'm quoting the client 15-25 hours of my time to facilitate this so I will be compensated quite well.
I think ideally, it's Egnyte + Buy their employees Laptops so they can work natively at home.
Any thoughts?
So, in my research
Egnyte:
Autodesk Vault:
Dell Server:
Synology NAS + VPN:
Any thoughts?
