geekhelp4u
- Cypress, Texas
Yep, that's Apple. They think the own their customers. Sad thing is, most of them are happy slaves![]()
Its funny that everyone posting on this thread is basically hating on Apple. Yes, maybe it is partially a control thing. But at the same time Apple has been using Hard drive temp sensors for years. This has not been on all equipment either. The trend started and has been limited to the all in one units, specifically the iMac. It all started with Imac G5s with the sensor mounted on the frame that secures the drive in the machine. Then with the later versions of the G5 iMac and the first Intel Imac was the cable plugged into the sensor which the was stuck onto the drive with adhesive. Then the aluminum iMacs introduced just the single sensor and cable which was stuck onto the drive, again with adhesive. The later versions of the Aluminum iMacs introduced the actual plug-in sensor where the drive themselves had actual pins in the drive. Now they have combined the SATA power cable and sensor into one, along with custom firmware on the drives controller board. I for one over the years have replaced hundreds of drives in these machines for heat related failures. Maybe over the years, the engineers have been working with drive manufacturers to find the best way to monitor temperature and provide adequate HD thermal control on these things and this was best that they came with? Yeah, people are going to be ****** and automatically point to Apple as the bad guy because Apple didn't take pity on Joe Blow who wants to swap his own drive or put in a larger one. But is Apple supposed to care about that? They are concerned with providing the most cost effective and functional method to address hard drive stability in their product.
I was going to post something almost identical to this. Everyone likes to complain about Apple, but when you get right down to it, their systems are among the highest quality systems on the market. That's not to say they're perfect or don't have problems....but give me a Macbook Pro unibody vs ANY PC brand even at a comparable cost...nothing comes close to being built as well.
The fact is, the proprietary drive is going to probably cause repairs to be more expensive than they should be, or make someone unable to upgrade.... but someone shouldn't be buying an iMac to upgrade the thing. It's a pretty much closed system with nearly 100% proprietary parts. Eventually there'll be an adapter or work-around for those that really want to do this, anyway.
Oh yeah, because they are "great engineers" who found a better way to do this...oh.. funny how TOSHIBA< DELL< IBM< ACER< HP...I could go on...figured out how to keep their machines cool and not restrict the user from replacing the drive.
With all the crap they pull you'd think people would stop buying their products, but unfortunately there is enough stupid people with excess money to keep them in business.
I think most Apple customers are very loyal because Apple makes a very good product. High quality hardware combined with the OS is a hard combo to beat. You can call it being a slave but I think most Apple users would look at you running AV , Ccleaner, defrags, scans ect just to keep the windows box running and call you a slave. Or how about fiddling endlessly with drivers in terminal in Linux just to get your sound or wireless to work?
I mostly agree with you, but have a couple points.
I don't know about your market, but in wa state in the US, most Mac users are different. One customer of mine just upgraded to the sandy bridge Macbook pro, not because she needed it (her "old" one was the last gen) but because there was a newer model available. She's not alone in her upgrade pattern, but not all Mac users work this way. Windows users tend to squeeze every last once out of a system. Most of the time a major failure, cause the update. Brilliant marketing by apple, but I think that mentality, buying every product, and update available, which you only see with apple fanboys, was what they meant by slave.
On windows users being slaves, you bet, Linux too. None of them are perfect, but they all have a place. Do you really defrag and run temp file cleaners that much? On my personal system, when I'm in windows, I don't even run an AV. I of recommend people do though. You need to watch out with that comment now. I've had 2 macs in this week with rogue apps. You also must not use Linux much, because I have no problems setting up and running Linux. It's very easy, but I'm not saying it's ready for end users. There is a lot I can only do in Linux where as with Mac vs windows, it's generally a preference. I like and use all of them.
IBM and Sony machines are clearly built better than apples....no contest. (of course thats my opinion, not fact)
Just because they look smoother and are cleaner doesn't make them a higher quality machine than the rest. (your opinion, not fact) When apples start sharing the same market as PC's your going to see just as many of them fail.
And saying people shouldn't be buying imacs to upgrade? Who the hell are you to tell someone what and how they buy it. You dont control the world, and Apple shouldnt be trying.
