pcservices
- Western CT
Had a customer drop off his daughters 2020 macbook air for a screen replacement. Replaced the screen, everything is working except for the camera. Under system info, camera shows not detected. Since the camera is built into the screen, we got another screen in case the 1st screen was bad. Ran into the same issue with the second screen. At one point under the system info, the camera did show a model ID but then that went away and there is no camera detected. We then reconnected the original broken screen and no camera is detected on this either. We ran updates for the OS, checked permissions, checked various programs on the mac that she had and no camera is coming up. Took the logic board out, cable is secured tight on the board and board looks fine. We reconnected everything but still no camera.
Of course the customer is insisting the camera was working before it came in, he saw his daughter using it, and unfortunately the tech did not check the camera before it was worked on. Is there anything else we are missing that we can check? We are going to talk to the customer about doing a backup reload to rule out software issues.
