DocGreen
- South Bend, IN
OK so I use Quickbooks for pretty much everything right now... yes, I know I should switch to one of the ticketing systems (PCRT, mHelpDesk, etc) but that's not going to happen today.
I feel like I could be doing things better, or more properly in Quickbooks. Here's the procedure I'm currently using...
I've been playing around with some of the features in Quickbooks, and it looks like I should maybe be using the "Job" feature where every time a customer calls (including repeats) I create the customer, and I also create a job under the customer... each new service is a new job. After looking into that and seeing how that works, I'm wondering what else I could be doing better.
One thing I would like to accomplish with Quickbooks is Work Orders. I've done some googling and seen some really convoluted ways to do it... Does anyone know of any methods? Maybe a plug-in?
- Customer calls, I fill out an Initial Contact Form (paper).
- If it's a new customer, I create the customer in Quickbooks.
- Use Quickbooks to create an estimate. Print one copy to PDF and file away on the server, Print 2 hard copies, one for the customer, another for their file.
- Pickup PC from Customer. They sign my copy of the Estimate and fill out a service contract (paper).
- If any changes or adjustments need to be made to the estimate, it is ammended and emailed to the customer., then saved/printed as above as a v2 of the original.
- When the job is finished, Estimate is converted to an Invoice. Invoice is saved/printed as above and emailed to the customer.
- When the computer is returned, customer is given a hard copy of the invoice. When payment is made, all copies are stamped as paid.
- Payment is "received" into Quickbooks.
- Deposit is recorded minus any processing fees.
