jzukerman
- Central Maine
I picked up a used HP Proliant DL120 G7 server off eBay for really cheap, to use for personal hosting of some VMs. Nothing client facing or critical. The server came with one 300GB SAS 15k hdd and an HP Smart Array P410 controller without battery or memory module. That means I'm limited to RAID-0, RAID-1, or RAID 0+1. I purchased two more 300gb harddrives used off eBay. Those drives appear to work fine. I setup a RAID-1 array with a spare, and installed VMWare ESXi and that worked fine, so the RAID card appears to be good.
I just picked up a battery, the cable between battery and memory module, and 512MB memory module for the raid controller to allow for RAID-5 configurations. When I installed them and booted the server up, the controller fails to initialize and says self-test failed. If I remove just the battery, same issue. If I remove the memory module, it'll boot up but no RAID-5 option.
As I'm a Dell guy, this is unfamiliar territory for me. I looked up all manuals I could find. Lights on the battery show SYS and AUX lights on solid, and light #4 blinks 1 second on, 1 second off. RAID card lights are saying initializing array, and never change with the battery and memory module plugged in.
I would think the controller would boot with a bad or missing RAID battery, but throw warnings about this.
Did I get a bad memory module and battery?
Here's the relevant part numbers:
HP 512MB Battery Backed Write Cache & Battery RAID Kit 462975-001 462976-001
HP Smart Array P410 Controller (AS 013233-001 Rev AE, Firmware Ver 5.76)
