Fretzen
Hi all,
It's my first post so I take the opportunity to present myself to the community.
Now to the point. I have a customer that wants me to expand his LAN to a room in his office that doesn't have any LAN connectors on the wall. They need high speed networking so WiFi is not an option. I will have to throw a new cat5e or cat6 cable to that room. The problem is that they are no internal LAN cable tubes to that room and even from the nearest LAN connector it would be a very large and dificult path to take the cable along the wall with a glue pistol. Also my customer says he wouldn't like to see so much cable running through his office.
Other option would be to use over wall cable racks but as I said is a long way the cable has to run and I even would have to drill some holes. He won't like that. Of course he would have to accept it if there is no other option but I found one possibility.
That room has power plugs, of course. Talking with the man that makes general fixes in the office (paint, electricity, etc.) he says that the power cord to that room comes from a plug in another room that has a LAN connector just next to it. So the possibility would be to pull the LAN cable through the same tube along with the power cords. I know this should never be done but it's a desperate case and it would be for only 5 or 6 m. (16 to 20 ft.). As it will be a good cable (cat5e or cat6 as I said before) maybe it's shielded enough to avoid any interferences.
Has anyone done something like this before? Do you think it will work without problems or are you sure it will not work? I will appreciate any feedback from you guys.
Thanks in advance.
Thanks in advance.
