lan101
You cannot make a diagnostic over the phone.
You cannot know the problem until you have the machine in front of you and you do some testing. You can make a few really good educated guesses, but they are guesses none the less.
For example: Customer rings in that his machine won't turn on at all. You tell him, oh that's easy. It's probably the power supply. A new one is X and the install will cost X.
They bring it in and the machine fires up in your shop. Now you have no idea what's wrong. Anything from an intermittent problem with the hardware to a fault with the outlet / wiring where the customer had the machine.
I've had a few in the past where it was an outlet issue/wiring of some sort.
As far as the diagnostic over the phone, I tell them it basically needs to be looked at to know for sure, but I give them a few likely scenarios of what it could be and what I charge for those services.
If you are going to get the job, they usually will book it right then and there, if they say I will call you back, maybe 1 out of 3 or 4 will. That's been my experience anyways on calls that it could be more than 1 scenario.
My success rate of closing the job is probably somewhere between 80 to 90 percent I would say, so that 10 to 15 percent that I lose could very well be a cheap skate or someone that was going to be hard to deal with.
Like you said it's pretty tough to make a "for sure' diagnostic over the phone, but we can usually make a pretty good "guess."
