Sky-Knight
- Arizona
Time to disable upgrades again! This update doesn't much with kernel changes or anything usually dangerous, and I'm really happy to see the improvements coming. however...
Take a peek at the major features:
Version 17.0 of NG Firewall is now available for download from Arista Edge Threat Management dashboard.
This release includes:
Multi-factor authentication - You can configure a TOTP code to log into the local web administration as a secondary authentication method.
DHCP Relay - The DHCP server for LAN interfaces can forward DHCP requests to a remote DHCP server to centralize IP address assignment across a distributed network.
WiFi regulatory domains - You can assign the regulatory domain based on your selected region so that NG Firewall updates the list of available frequencies.
New WebFilter categories.
Persistent NIC mapping.
Note that one at the bottom...
If you have any manual configuration in this space, you're probably going to have to remove that to prevent conflicts. Also depending on how that upgrade slides in, it might break on the next reboot. So I'm suggesting a planned upgrade akin to a full kernel upgrade, have someone on hand to deal with it!
