brandonkick
So... small business. They have a comcast business gateway, standard 4 ethernet port with a 2.4ghz and 5ghz wifi radios. They have a total of three switches.
Comcast Gateway feeds one 48 port switch, which in turn feeds most desktop computers directly, but does have a lead that goes to a 8 port switch for one "office" and another 4 port switch in another office.
Total of 15 desktop computers, 7 printers and maybe as many as 15 more cell phones that would be joined to the network. Yet it appears the network is running out of network addresses. Randomly computers won't be able to get online, and I find they are given an IP address WAYY out of range. Standard default gateway is 10.1.10.1 and DHCP pool ranges from 10.1.10.100 to 10.1.10.240 with a subnet mask of 255.255.255.0
Should be plenty of addresses, but eventually machines will start acting up. I do an ipconfig/all and the IP they are pulling is like 169.192.245.27... no where even close. I noticed too that the subnet mask goes to 255.255.0.0
If I manually fix the machines IP address to a valid, in range address.. it works. I started the pool at 100 so I would have plenty of addresses to hardware things. I have the two synology units on .15 .16 .17 and .18 for example.... CAD plotter on .63 / laser printer on .64 and a desktop hosting quickbooks set to .55 with
First thing, is that I wasted a TON of time with comcast tech support. They told me, I have "too many devices connected" for the 150MB speed package, and actually suggested removing printers from the network to ease "congestion". Also tried to sell me a higher speed package. I iterated to her many times, the internet wasn't "slow" and most users bandwith needs were like so minimal that 3G cellular would do. Obviously didn't know what DHCP meant, or my IP address issues... more concerning was they told me there is no "higher level tech support" available, and that she was the only one who could help me (lets reboot the modem, lets check the logs, hmm... let me send a new signal) beyond that they have a tech coming tomorrow, who will likely not know anything beyond what this girl did in terms of networking. I refuse to believe they have no "L2" support (I think that is what it used to be called)....
I want to know how to tell if the pool is used up, and why. I do believe this is what is happening, but have no idea why. There aren't nearly enough devices for it to make sense. I was thinking of expanding the DHCP pool even more... but the pool should be plenty wide as it is.
Other tid bits that may help, all switches are unmanaged. There are two other devices, a unifi AP and a linksys access point, on the network. Neither doing DHCP... but all affected machines are wired anyways.
