Coastalbendcomputers
- South Texas
This is going to be long but hopefully detailed. I just cannot figure this out, everything was working fine for 2+ years then it just started causing the error. Every Workstation on the network goes not responding for 10-20 seconds after hitting print then it starts to respond again and the print comes out of the xerox.
First the network
Workstations (4 Wired, 2 Wireless all Win7 x64) > Patch Panel > Unmanaged Switch
Xerox > Patch Panel > Switch
Server (AD, DNS, no DHCP) > Unmanaged Switch
Router (DHCP) > Unmanaged Switch
Originally all workstations had there own driver installed. I removed all of them and setup the print server. Same problem.
Swapped out the router with a known good. - Same Issue
Buypassed the patch panel and went directly through the router. - Same Issue so it was Workstation > Router | Server > Router | Printer > Router
I messed around with bidirectional settings and changed from Raw to LPR this has helped me with driver issues in the past and removed SNMP Status per Xerox Article.
Print directly from my Laptop to the Xerox hardwired - Worked with no problem!
Print directly from the server to the Xerox Worked!
Setup was Server > Switch > Router | Printer > Switch > Router
After this the Customer got a new Xerox going from Workcenter 7545 to a 7845 with this change they has had different drivers. - Same issues, Same things worked.
I feel like it was a permissions issue but I have created an admin user for the xerox and gave it full permissions on both the printer side and to the scan to network directory just in case. I have also made sure the Everyone user had full privileges to print and manage the printer. I checked and all are able to set there own printer properties from there workstations. I even tested adding one of the AD admin Users directly to the printer and gave him all privileges to see if it would change anything and it didn't.
1 other note they also have a Brother Wireless Network Printer. Installed and shared through the server. It prints jobs quickly with no issues. So this makes me think the server is fine. Also nothing changed on the server between when it was working and when it stopped.
I have disabled TCP Chimney Offload, RSS, and Receive window auto-tuning level. As well as removing the antivirus temporarily.
1 last note I was just testing and downloaded a random HP network printer PCL 6 driver and installed it for the xerox and it worked!! Quickly with no problems just missing a lot of features which makes since since it's not the xerox driver. The odd thing here is this Xerox driver is not new it's been around we didn't update them to start the issue. As you can see I have tried a lot and I'm left head in hands, please help me.
First the network
