Workbench pc repeat activations
citizensmith
DXB, UAE
Monday Morning idiot question
I used to have a trustey workhorse xp machine on bench. Sidepanels always off, extended power leads & drive cables always hanging out. It was graet for things like FABs, drive testing and was always being reconfigurred. Figured it was time to retire it but now replacement w7 box is always bleeting about activation when working with users drives. I know this is a "significant" hardware change but its a real drag continually doing the phone thing.
Am I making a noob mistake here or is there an easier way than putting an earlier clone image back on the w7 box or using external usb-sata box?
^^ Thats' reassuring :( I guess I must be doing it wrong :facepalm:
Yesterday added added an IDE drive & vista laptop drive. Everything worked fine with no hassle. Jobs done so removed extra bits. Today w7 pro wants to be activated again again :confused: .
Previuosly used PE / linux boot disks for this sort of thing so maybe there's a problem with the original instalation
My main system is a Windows 7 unit and it has a BlacX esata dual drive doc that I frequently use for data recovery or drive cloning. Never been prompted to activate. So long as the main drive isn't changed you shouldn't be prompted for that.
This has always been my understanding. I have a windows 7 pro as my bench machine. Could Home Premium trip this up? Always hook up clients drives to it never had to reactivate.
Thanks DCGPX thats' a great idea. Problem onlly seems to affect the test rig. My office pc is fine with swapping drives. Think its' hammer time ;)
Never had this problem with my bench machine running Windows 7 Pro. That's had so many drives in it that I have to manually assign drive letters cause they don't get automatically assigned anymore.
But as mentioned above, the boot drive never changes...
Talking about activation on the phone... just managed to complete one in 3 minutes 32 seconds.
My fastest time ever :)
Same here about drive letter assignments. I can see a competition coming up for the activation :)
Sidetrack but is noautomount enabled?
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MountMgr\NoAutoMount
Quick googleshoo says if value 1 it will no longer assign letters?
Or uninstall USB controller, reboot and the check value then
I've loads in and out and not met unassigned letters yet.
Just a thought!
Just a thought!
Nothing's changed from the default install and sometimes it will assign a letter and sometimes it won't.
I think I need to scrub non present devices and whatever else I can find to clean it up. Failing that I have a shortcut to disk management handy.
Not surprised as this machine has had probably close to a thousand different drives in it since 2009.
Embarrased but Resolved
Can we have a :facepalm: icon please?
Did a clean install not from a clone this time. After rebooting showed 3 days to activate ? Online activation failed. Noticed sidebar was showing wrong time and date. Reset both and it activates fine.
The cmos battery was dead. Hate it when I jump right in to fix the complicated fault and miss the "obvious".
Thanks for all the ideas guys. And Gal:)
Espeically when that's already been mentioned by alice !
