Wireless options for this setup?
MobileTechie
UK
I have a customer with a wireless router which serves his home computers. However he also brings laptops from work which are locked down and will not allow wireless connection. So he wants to have a little switch/hub upstairs that connects to his wireless network but allows the work laptops to be plugged into it via ethernet.
What are the options for this?
I don't think I have seen a wireless router that didn't have LAN ports on them.
Another idea is purchasing another router and putting it between the wireless router and the internet. Just connect the laptops to that router.
Any access point/router that allows WDS (Wireless Distribution Service) will work. I get mine through IC Intracom.
Rick
How about just obtaining a switch and connecting it to one of the ethernet ports on the wireless router, or does the wireless router not have ethernet ports? If not, just get a wireless router with ethernet ports.
Does your client want to use the work laptop(s) in various locations within the house? If so you can use Powerline Network Adapters. At least two are needed - one plugs into a wall power outlet and connects to the router/switch via ethernet, the other also plugs into wall power outlet and connects to the computer via ethernet. Essentially they use the copper in the power lines as an ethernet cable. Pretty handy devices - I've used dozens of them in locations where it was impossible to run cable and wireless wasn't an option.
As Allan22 and krutoi mentioned, powerline ethernet adaptors are also a great solution. They run about $100 for 85Mbps and $130 for 200Mbps. I've used them a few times and they don't always like surge protectors and power strips, so sometimes you need to free up a socket directly on the wall, but they work great!
