Aloha everyone. Have a strange one here. Was at a customer doing a general service and found 144 reallocated sectors on the hard drive. Imaged the old hard drive using ddrescue, ended up with 2 blocks that could not be rescued (1 TB drive). Used ddrescue again to copy the image to the new hard drive, it finished with no problems. Machine booted up fine, ran sfc /scannow and chkdisk - everything was OK
I powered down last night and this morning I had to r&r the motherboard - someone else had replaced it at some point and the ethernet port was blocked by one the grounding tabs for the case. I did have to remove the hard drive to get to one of the motherboard screws, but everything went back together OK.
Now, when I try to boot it, I get the inaccessible boot device error. ??? Startup repair doesn't fix it. When I go through the Win 10 advanced options and get to the command prompt, I can do a 'dir' on the C:\ drive and it works, I can open notepad and save a file to the c: drive, so it's not like the hard drive has stopped working.
I'm guessing somehow the bcd stuff got messed up (don't know, or understand how, since it was working yesterday).
I tried the following sequence that I found in many places on how to remove the existing bcd and create a new one:
bcdedit /export c:\bcdbackup
attrib c:\boot\bcd bcd.old
ren c:\boot\bcd\ bcd.old
bootrec /rebuildbcd
My understanding is the the last command is supposed to show that it found a Windows installation to add to the bcd. But it shows the found as 0 (zero).
I'm attaching diskpart output. This is a gpt disk (from what I can see in diskpart) and I'm unsure if any of the partitiions should be marked as active. Or if a required partition is hidden when it should not be.
This is an HP Pavilion 500 pc running Windows 10 AU.
Any assistance would be greatly appreciated.
Harry Z
bootrec /rebuildbcd
Harry Z
