PcTek9
- Mobile, AL
See, this is exactly the reason that many of the large pc repair companies, just remove the drive, copy the entire data to another drive. Then they wipe the original drive and reinstall windows and add the users data back. Because of LEGALITY. Once a system is compromised you simply cannot guarantee that (you) found every virus, every trojan, ever piece of malware on that system.
As I have explained to you all, file dates, sizes, etc. are easily changeable. I can directly access that information from inside many languages.
Personally, you will take a LOT of time to clean a system like this manually. WHAT I STRONGLY ADVISE if you are doing this manual method, is to look at the scripts created by Methical (Lord of the scripts) and AtYourService (Script Genius). They have made these scripts available on technibble.com in the scripting forum. Some of them automate the process of removing viruses and trojans by launching scanners, turning off indexing, system restore, uac, etc so the system will run faster (maybe even be usable at all). So that it can be cleaned and you can get any speed to clean it.
Yes you can clean a pc manually. But it absolutely does not guarantee a 100% clean machine. This is why (because of legal reasons) that most big chains simply copy user data and settings, then format and reinstall then scan all user data then put it back on the pc.
I can be more clear by saying: Antivirus companies dont usually find every virus. They might find all of them on most of the systems you work on, but for example, an individual antivirus company might only successfully find 73% of test viruses in a folder. Because people do create a viruses and trojans all over the world and some of these won't be detected right out of the box. This means you may think you got every virus, b/c you scanned a system with avast, avira, kaspersky, fprot, etc... but the system could have a virus that none of these scanners pick up yet. With that said, someone could say "how can you guarantee that you completely cleaned the users data, couldn't it contain an unknown virus, even if you wipe the drive and scan the users data?" That's a legitimate argument, and the answer is yes, it could. The difference is, the virus/trojan is not active on the system when you give the system back to the user. Whereas if you don't format and reinstall -technically- there is the remote possibility that something could be remaining active and unseen by you the technician. So without sounding absolutely hopeless about it, it is better to hand back a system with an inactive virus/trojan hidden in the user data than an active one.
