sapphirescales
- At My Computer
@MisterT For the sake of your clients, I recommend you learn more about Macs before claiming you can fix them. I'm the biggest Apple hater there is but I have an understanding of how Mac OS actually works so I'm able to fix problems that my clients have with older hardware and software. The certificate issue you're describing is easily remedied by changing the date in the terminal before you try to go through the upgrade/install process.
I find it hard to believe that the person you spoke to at Apple was unfamiliar with this, as this is one of the most basic, well-known issues when it comes to installing an older OS (and by "older" I mean anything no longer supported by Apple). When it comes to the app store, it's your responsibility to have older versions of popular software available for your clients. Some developers offer older versions through the app store, but like a phone, if you don't have the most recent version, developers aren't going to support the app on your device anymore. Live with it.
It's the same thing when it comes to all software, including printer drivers. Go on. Go find a printer in Target or Walmart that supports Windows 7. They don't exist because Windows 7 is no longer supported. Want to use Adobe CC? Too bad. Heck, they won't even support Windows 10 versions older than 1909. The problem isn't the app store, it's your ancient software that's no longer supported. Want to use a printer and Photoshop in Windows 7? Fine. I hope you kept a copy of CS6 and have an old printer lying around, because that's the only way you're going to get those things in 2021.
Live moves on. If you want to still use ancient hardware/software then that's your right, but don't expect developers to continue supporting your ancient software. If you want the latest and greatest, then you need to upgrade. It's very generous of Google to continue supporting Mac OS 10.11 but most developers abandoned 10.11 years ago. It's a 6 year old OS that Apple dropped support for 2 years ago.
