Cambridge PC Support
- Cambridge UK
I picked up an old Sony Vaio laptop yesterday. Customer said it was running slow, so I quickly ran GSmartCtrl (via Parted) on the HDD with a short test which came up fine.
Brought it back to the workshop, cleaned it up. Then I put some more memory in it to perk it up a bit more. Booted up fine into XP. I then decide to run a memory test on it just to make sure it was all happy.
Hitting F10 & F12 alternately to get into the boot options I accidentally fall into the Sony Recovery option, so I immediately cancel out of that and then proceed to go into the CMOS setting and set my memory stick to boot first. Boot up and it comes with "Operating System not found". So I think that maybe it's not liking my memory stick so I try another one. Same thing happens.
So then I try to boot from the HDD, with exactly the same result. So I'm thinking that either the Sony Recovery option has changed something or the HDD is failing. I've stuck the HDD on my bench machine to run a long test.
While it's doing that, I'm trying the memory stick again, which worked fine yesterday but now I'm having no joy.
I've checked the CMOS settings, nothing odd there. So I'm a bit stumped.
