Weird problem - USB device isn't detected by software
joe talin
Israel
Hi,
I have a weird problem:
It's about vinyl cutter(cricut). It's connected by USB to a pc and has it's own software.
It works fine in two windows 10 desktops.
It also did work fine in a windows 10 laptop some months ago.
But not when i try to install it , i follow the install instructions as specified, i install the software , and when the software asks me to connect the device to USB(in the pc port) i do so, but it doesn't recognize it.
And i don't see it in the device drivers - not as a cricut device and not as an "undefined usb" device.
Further , i've tried to use a USB diagnostics software(usbdeview) - and it does see it and see when i connect it.
How do i fix this ?
Does it do the same thing in all USB ports? One group of ports could be bad, or have a compatibility problem with the device.
Have you tried it on different USB ports on the machine? Connect to USB 2.0 instead of 3.0 ports. Different USB cable.
Seems like a hardware issue if it doesn’t show up at all in Device Manager.
