mdownes
- Dublin, Ireland
Hi all,
One client, a school, has 50 PCs of a particular make/model running Windows 10 Pro, which an MS refurbisher supplied. All were switched off for about 10 weeks over summer. For some reason, after being switched back on in the last week, 14 of them underwent the following changes within a few days of each other:
1. Windows seems reinstalled (Windows.old folder now exists on c:\)
2. Hostname changed to the form WIN-[random_characters] also many other settings are now default
3. Windows no longer activated and trying to activate yields this error:
"We can't activate windows on this device because we can't connect to your organisation's activation server. make sure that you're connected to your organisation's network and try again. etc, etc. Error code: 0xC004F074"
4. PCs can no longer log onto domain
5. All have the update KB4021572 installed on the same date that windows.old directory was created. I've checked two PCs unaffected by this issue, and they don't have that update. I understand this update has been problematic but I can't find anyone else for whom it's caused these symptoms.
It looks as though someone reverted to a restore point, but if I try access system restore, it's turned off on some PCs and on others, the only available point is one after the windows.old folder was created. Also, as far as I know, nobody was around to do that. There's nothing in the event viewer before this 'big bang' moment.
Can anyone shed any light on this?
Thanks in advance
Thanks in advance
