glricht
- Zephyrhills, Florida
I was perusing some tech forums and came across a post saying that in Windows 7 you could use SFC to check the Windows files on a slaved drive. I've only used SFC to check the booted Windows (e.g. SFC /SCANNOW) and wasn't aware the Win 7 version could check an off-line Windows. Checked SFC's command line options and there it was:
MS gives this example for checking a file on a slaved drive:
sfc /SCANFILE=d:\windows\system32\kernel32.dll /OFFBOOTDIR=d:\ /OFFWINDIR=d:\windows
However, when I tried the above MS example on my Win 7 Ult 64-bit using a slaved Win 7 H.P. HD, SFC always comes back with "Unable to start the repair operation".
Seems that this would be useful in certain cases. Have you done this? Did it work for you?
Sfc [/SCANNOW] [/VERIFYONLY] [/SCANFILE=<file>] [/VERIFYFILE=<file>] [/OFFWINDIR=<offline windows directory> /OFFBOOTDIR=<offline boot directory>]
/SCANNOW
Scans the integrity of all protected system files and repairs files with problems when possible.
/VERIFYONLY
Scans integrity of all protected system files. No repair operation is performed.
/SCANFILE
Scans integrity of the specified file and repairs the file if problems are detected, when possible.
<file>
Specified full path and filename
/VERIFYFILE
Verifies the integrity of the specified file. No repair operation is performed.
/OFFWINDIR
Specifies the location of the offline windows directory, for offline repair.
/OFFBOOTDIR
Specifies the location of the offline boot directory for offline
