Thunderbird message filters often miss messages on first few runs - Why?
tankman1989
I was wondering if anyone else runs into this. I have been creating a lot of filters for Thunderbird as the number of emails I'm getting daily is making it difficult to sort. I have found that VERY often when I create a filter and then run it on the inbox it very often misses a lot of messages. I can run the same filter 3-6 times and each time I see more and more messages disappearing. I can't figure out why or how it can miss so many messages.
An example is this. I select an email from Newegg. I open the email, right click on the "From" and select "create a From filter" and select the destination folder for the message. I probably had over 50 of these emails in my inbox and the first time I ran it the filter moved maybe 5-8 messages. I then ran it again and it moved none. I then highlighted all the messages in the inbox and selected "run filters on selected messages" and it only moved a few more. I then kept running it and finally after 3-4 more runs they were all moved. This happens with any email address and found that 5/5 filters have performed this way with it never finding 100% of the messages.
Does anyone else have any problems with Thunderbird filters? Is there any reason that can be thought of that would cause this? Thanks
I know we are all techs here, but here you are just going to get a lot of speculation or no response at all. This is really an application specific feature kind of question that's more likely to get some decent feedback if posted here.
I noticed that I hadn't selected "Match any of the Following" which meant that the message had to adhere to all the rule I inputed. This still doesn't explain why it was not getting all of them in one running of the filter. I wonder it has anything to do with the massive amount of email it was sorting? Perhaps I hadn't allowed it to finish running, IDK.
Thanks for the suggestion above!
Just speculating here..:rolleyes:
But when blocking 'specific' email messages, you may wish to check out the
email source code or the headers before hand. This may give a clue as to
why some get blocked and some don't.
Good Luck!
