tankman1989
I'm copying files from a local eSATA drive to a samba share and the system keeps locking up at around 75% completion of the data transfer. I first tried copying the same directory (about 30Gb) and it would lock up around 73-75%, the system would freeze with a strange buzzing sound. I thought it was a freak occurance at first and then I tried it two more times with the same files and had the same thing happen.
I then tried to copy another folder of about half the size and the same thing happened at about the same percentage.
The only thing I can do is a hard reboot/reset.
There is more than enough room on the target drive and I'm using Teracopy to copy the files.
These files originated on another machine with a USB drive. I transfered them to my main desktop and this is where I'm getting the error (transferring from my main desktop to my samba share). I tried transferring from the USB drive on the other machine to the samba share and I get no lockup or errors like I do with the main machine. I'm also using Teracopy as well.
Does anyone have any idea what might be causing an error like this and what to do to fix it?
