For the most part, they are pretty universal. Most standard 15.6 LED screens (for instance) can be replaced with a comparable 15.6 LED screen. We only keep two types of screen in stock.
Standard 15.6 Glossy LED screen with bottom left connection.
An example of the above is this screen
here, which we order every time we need to restock on these screens.
Specs from the above page:
Laptop Screen Backlight: LED
Laptop Screen Connection Type: 40 Pin Bottom Left
Laptop Screen Resolution: 1366x768
Laptop Screen Finish: Glossy
Laptop Screen Size: 15.6"
Standard 17.3 Glossy LED screen with bottom left connection.
Laptop Screen Backlight:LED
Laptop Screen Connection Type: 40 Pin, Bottom Left
Laptop Screen Resolution: 1600x900
Laptop Screen Size: 17.3"
We also keep a few of
these and
these around for the odd ball screens with the bottom right connections. These screens tend to be way more expensive, so the adapters are a good solution --just make sure you connect it right or you will fry the cable, screen or worse.
We special order everything else for the moment.
