sort excel sheet by characters.
computertechguy
New Jersey
I have been trying every which way I can and I can't figure out how to get an excel column to sort by character qty..
We have a column with a customer code which consists of a total of 5 characters or 6 characters.I need to sort by these as 5 characters means one thing to my client and the 6 means another.
Any thoughts?
Create a new column that takes the =LEN(<column letter>)
Then do a custom sort like normal: first on the length column ascending and then by whatever other columns you want.
Sent from my iPhone using Tapatalk
For some reason the LEN= doesn't work It still randomly puts the number value willy nilly.
I'm confused (normal). Can you elaborate on how the desired sort would look? What is Excel doing that you don't want? Do you want the 6-character strings to sort after the 5-character strings?
@Tech Savvy is correct.
I copied your data into a new spreadsheet. I created a Length column with the formula =LEN(F5) and copied it down. This gave the correct length in characters of the Code column entries. Like this:
Then I did a sort first by the Length column in ascending order, then by the code column in ascending order. Like this:
Which gave me the expected answer. All of the "5's" were sorted alphabetically first, followed by all of the "6's". Is this what you were looking for?
