Should I run Big Sur or Replace w/ Linux
Blues
Tennessee, US
I have an early 2014 Intel MacBook Air I am playing with and it looks like it supports up to Big Sur but that is long ended for support so I am thinking if the computer is actually used I should just drop MacOS for a current Linux option but curious the general opinion of TN. I know it is an old system not really worth running or running much but for a system to toy with I am wondering if should keep it on Big Sur or just jump into Linux on it.
Well, the question really is: Can you do anything at all of worth by keeping it on Big Sur?
Your answer to that will dictate what you do next. And depending on precisely what your goal(s) are, the answer to that question could break either way.
Otherwise, besides OCLP, I would recommend wiping it and disposing of the hardware or selling it dirt cheap. From there, I would upgrade the hardware to a modern MAC or if I wanted to run Linux probably do it on a PC
I am also trying to think if I give this away or sell it then Linux might be an issue but atm it is something to toy and test with I might give the OCLP a try to see what it can do but does using that have issues similar to Rufus for Windows 11 on unsupported hardware? I think if I got rid of it ChromeOS Flex might be a good answer I haven't really ever looked at it as for me personally it seems like a terrible choice.
Apple will have nothing to do with it if you call them for support, but that's only to be expected.
The main thing that you need be aware of is that OCLP only works for macOS up to Sequoia, so you have to be very careful never to upgrade to Tahoe as this will break things rather badly. Apple keeps presenting Tahoe as a recommendation in Software Updates, which means it's fine for your own use but if you give it away or sell it you will get a call from the next owner when they click on the Install button and wreck their computer.
Ok thanks so not the same as Rufus but a little shared risk in there Id call it so if I go to sell it ChromeOS might be the best for simplicity and general use.
You know your customers better than I do, but I'd be reluctant to sell a twelve-year-old laptop with an unsupported operating system to anyone. In your position I'd slap Sequoia on it and keep it as a daily driver to stay more-or-less fluent in the Apple ecosystem, which is exactly what I did with mine and it worked out very well - I've been using it with various supported and unsupported versions of macOS for the last eight years and it's never missed a beat.
If I hadn't retired five years ago (yay!) I might still do the same but I'd probably also treat myself to a MacBook Neo as a business expense. They're cheap, gorgeous and an excellent way to keep in touch with what (some of) your customers are using.
A word of warning about Linux on this machine, since I believe we have the same model. I briefly swapped out its SSD and set it up with Ubuntu (that's what happens when you have time on your hands) and it was a bit of an uphill struggle. There were a few hoops to jump through to get the bootloader to recognise the SSD, then rather a lot more to get the right WiFi driver installed and stable, and I never did get the camera working well. It was smooth and fast when I was done but it always felt a bit delicate, in a way that macOS never did. It was a relief when the SSD popped its clogs and I had an excuse to go back to macOS. Ubuntu on every originally-Windows machine I've used was much more robust and far less painful.
So I haven't swapped the SSD but I did wipe it as the original owner just handed it over to be wiped and disposed of. I tried a few Linux distros on it and fortunately I have a Linux friendly USB Wi-Fi which solves much issue with getting it going and the built in Wi-Fi installed but funny enough Linux Mint Debian Edition saw it w/ no added work. I plan to drop ChromeOS on there soon for a test as I feel it might be the best suited OS for this device if I sell or give it away.
I have a MacBook Pro (early 2015) that runs Linux Mint without issue. I choose not to run anything that isn't currently supported and fully updated. The hardware is still good, and with a supported OS on it there's no reason not to use it. However, running an outdated and unsupported OS isn't a great idea. Trying different Linux flavors is a perfectly legitimate use of older hardware. Should you decide to either sell or gift the machine to someone, I would do so with a currently supported OS.
