InHomeComputerHelp.com
- Honolulu Hawaii
Using Linux Mint and a powered USB 3.0 hub and starting with the HD plugged in I was able to get it to show in the computer folder. It will not, however mount. Plugging it directly into the USB port caused a low beeping which I believe indicated not enough power. Research showed as the HDs get older (2 years old) they may need more power to mount. Thus unplugging everything from the 3.0 hub except the external HD finally got it to at least show up.
In Windows the external hard drive did not show up on disk manager. It also would not list using the command line from disk manager list disks.
The computer even locked up on me while I was right in the middle of typing this which is very unusual. This happened while the external hard drive was plugged into the 3.0 hub.
The client told me it went bad about a week or two ago and she has important pictures in their naturally. She reported that it did show up on Windows but she couldn't open any files it appeared to be empty.
I appreciate any help thank you.
Rick
PS Got an input/output error running Gparted
Rick
