RepairShopr Schedule Change
therealcrazy8
Minnesota
I have added the code from Repairshopr that shows the schedule on my site. It shows times from 8:00 am - 4:00 pm. I will only be able to start off doing 6:00 pm - 10:00 or 11:00 pm. Im assuming there is a way to alter that, but after all of the time I have spent looking through the setting for everything, I cannot seem to find where i could edit the schedule. Can I edit the days/times as i want and if so, how?
Are you referring to Web Based Appointment Bookings?
You change those in the app center where you enable the website bookings. If you enabled it to put on your site, you should have seen those settings on the same page.
Man I was in there and I thought it was all "apps" and offers. I didn't realize that it actually had those typs of settings. Thanks for pointing that out. I got it set up now. :)
Also a trick that isn't always obvious, when you want to block out a day - just use the 2 way calendar sync and throw something on your calendar. (and set the appointment booking settings to only run 1 concurrent appointment). That should give you a super quick way to block out a day.
