Blues
- Tennessee, US
Looking for recommendations for an external RAID box.
Here are the requirements and intended use:
At least 2 Drives
Must Support RAID 1 if supporting 4+ drive RAID 01/10
Will house main documents for main PC and media files for streaming on local network and possibly over the web down the road.
I am figuring either eSATA or USB3 as they are both supported on system it will connect to. As I understand it USB3 has a slightly higher top speed however the drives won't hit that as well eSATA can provide a constant speed. The only draw back is that I believe the system will need to support a particular feature to use RAID over eSATA can anyone confirm and elaborate on this. The application used for the streaming is PLEX I don't know that this will impact anything but in case it does.
This will be replacing an on board RAID that has had 1 drive fail recently.
At least 2 Drives
