Matthew Morgan
- Hereford
Anyone had problems with 2012 Essentials and integration with Azure / Office365
it seems as though the "Windows Server Essentials Email Service" is crashing, log files give the bellow i have been googling and looking for an answer for days
it seems the dashboard thinks azure is enabled but i cant disable it running the wizard brings back "An Unknown error has occurred. check your connected to the internet "
[31960] 151130.090141.5447: SharedServiceHost: Information: [0] : ==========================================================
[31960] 151130.090141.5916: SharedServiceHost: Information: [0] : "C:\Windows\System32\Essentials\SharedServiceHost.exe" C:\Windows\System32\Essentials\EmailProviderServiceConfig
[31960] 151130.090141.5916: SharedServiceHost: Information: [0] : Loading service information from "C:\Windows\System32\Essentials\EmailProviderServiceConfig".
[38052] 151130.090141.6072: WinSrvEmailProviderSvc: Microsoft.WindowsServerSolutions.O365Integration.O365ManagementService, Wssg.O365Provider, Version=6.3.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 is created as hosted email service provider
[38052] 151130.090141.6229: WinSrvEmailProviderSvc: Microsoft.WindowsServerSolutions.PasswordSync.PwdSyncManagementService, Wssg.PasswordSyncProvider, Version=6.3.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 is created as hosted email service provider
[38052] 151130.090141.9666: O365Integration:BackgroundTaskManager: BackgroundTaskManager.StartTasks called
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: Starting UpdateDomainTask
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: updating UpdateDomainTask timer to: TimerSettings: DueTime=00:00:00, Interval=01:00:00
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: Starting UpdateSharepointAddressTask
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: updating UpdateSharepointAddressTask timer to: TimerSettings: DueTime=00:00:00, Interval=1.00:00:00
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: Starting UpdateO365IntegrationDataTask
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: updating UpdateO365IntegrationDataTask timer to: TimerSettings: DueTime=00:00:00, Interval=01:00:00
[38052] 151130.090141.9666: O365Integration:BackgroundTaskBase: Starting UpdateCachedSkuInfoTask
[38052] 151130.090141.9822: O365Integration:BackgroundTaskBase: updating UpdateCachedSkuInfoTask timer to: TimerSettings: DueTime=00:00:00, Interval=1.00:00:00
[38052] 151130.090141.9822: O365Integration:BackgroundTaskBase: Starting UpdateMSOSecurityGroupDataTask
[38052] 151130.090141.9822: O365Integration:BackgroundTaskBase: updating UpdateMSOSecurityGroupDataTask timer to: TimerSettings: DueTime=00:00:00, Interval=1.00:00:00
[38052] 151130.090141.9979: PasswordSyncManagementCoreFactory: Creating PasswordSyncManagementCore instances
[38052] 151130.090142.0135: PasswordSyncManagementCore: PasswordSyncManagementCore.Initialize
[38052] 151130.090142.0135: PasswordSyncManagementCoreFactory: PasswordSyncManagementCore for AzureAD was created
[32148] 151130.090142.0291: MSOSecurityGroupManager: Sync queue is empty.
[16152] 151130.090142.0291: PfBinding: Information: [0] : Adding service dns identity [ESS2012] in proxy endpoint.
[22248] 151130.090142.1541: UpdateO365IntegrationDataTask: Failed to get all users : O365ConfigurationFault = NotActivated
Microsoft.WindowsServerSolutions.O365Integration.O365ConfigureException: Operation cannot be called if O365 is not activated on the box yet
at Microsoft.WindowsServerSolutions.O365Integration.O365ManagementCore.CheckState()
at Microsoft.WindowsServerSolutions.O365Integration.O365ManagementCore.QueryAllOnlineUsersInternal(Boolean throwOnFault)
at Microsoft.WindowsServerSolutions.O365Integration.UpdateO365IntegrationDataTask.Run()
[15844] 151130.090142.1541: O365ClientProvider(ICallback): Channel_Closed called
[15844] 151130.090142.1541: O365ClientProvider(ICallback): Provider disconnected
[23556] 151130.090142.1541: UpdateMSOSecurityGroupDataTask: Start UpdateMSOSecurityGroupDataTask
[23556] 151130.090142.1541: MSOSecurityGroupManager: Full sync task will start in 00:10:00 minutes.
[23556] 151130.090142.7010: BecWebServiceAdapter: Connect to BECWS failed due to known exception : System.ServiceModel.FaultException`1[Microsoft.Online.Administration.WebService.InvalidHeaderException]: The creator of this fault did not specify a Reason. (Fault Detail is equal to Microsoft.Online.Administration.WebService.InvalidHeaderException).
[23556] 151130.090142.7010: UpdateMSOSecurityGroupDataTask: Failed to run UpdateMSOSecurityGroupDataTask: O365ConfigurationFault = Communication
Microsoft.WindowsServerSolutions.O365Integration.O365ConfigureException: Connect to BECWS failed.
at Microsoft.WindowsServerSolutions.O365Integration.BecWebServiceAdapter.Connect()
at Microsoft.WindowsServerSolutions.O365Integration.BecWebServiceAdapter.get_Client()
at Microsoft.WindowsServerSolutions.O365Integration.BecWebServiceAdapter.<>c__DisplayClass70.<ListSecurityGroups>b__69(ListGroupsRequest r)
at Microsoft.WindowsServerSolutions.O365Integration.BecWebServiceAdapter.InvokeWebServiceWithRetry[TRequest,TResponse](Func`2 func, TRequest request)
at Microsoft.WindowsServerSolutions.O365Integration.BecWebServiceAdapter.InvokeWebService[TRequest,TResponse](Func`2 func, TRequest request)
at Microsoft.WindowsServerSolutions.O365Integration.BecWebServiceAdapter.ListSecurityGroups()
at Microsoft.WindowsServerSolutions.O365Integration.MSOSecurityGroupManager.CleanUpMSOSecurityGroupData()
at Microsoft.WindowsServerSolutions.O365Integration.UpdateMSOSecurityGroupDataTask.Run().
[23556] 151130.090142.7010: UpdateMSOSecurityGroupDataTask: End UpdateMSOSecurityGroupDataTask
[9152] 151130.090242.0092: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[11456] 151130.090342.0272: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[25424] 151130.090442.0363: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[16036] 151130.090542.0441: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[22652] 151130.090642.0484: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[14440] 151130.090742.0528: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[36316] 151130.090842.0584: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[25912] 151130.090942.0679: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[8008] 151130.091042.0717: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[31628] 151130.091142.0766: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[31628] 151130.091142.1547: MSOSecurityGroupManager: Start full sync task
[16044] 151130.091143.1547: PfBinding: Information: [0] : Adding service dns identity [ESS2012] in proxy endpoint.
[19736] 151130.091143.2953: PfBinding: Information: [0] : Adding service dns identity [ESS2012] in proxy endpoint.
[31628] 151130.091143.3110: MSOSecurityGroupManager: End full sync task
[19424] 151130.091143.3578: AlertFramework: Subcomponent: LocalAlertManager > LocalProviderClient_ConnectionOpened:
[31628] 151130.091143.3891: AlertFramework: Subcomponent: AlertAgentProviderClient > GetAllAlertsInfo: trunk.HasMore=False, count=8
[31628] 151130.091143.4047: AlertFramework: GetLocalMachineSID: The local machine Sid is S-1-5-21-763314788-1569688668-751554549-1180
[20420] 151130.091242.0827: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[40988] 151130.091342.0867: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[26036] 151130.091442.0906: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[27668] 151130.091542.1003: DomainInformationHelpers: DsBind with domain controller ESS2012.dtbc.local return code: 0
[34000] 151130.091550.8035: O365ManagementProvider(IO365Callback): Deactivate:150313f1-fbba-457f-85cb-c0ba1c460013 starts
[34000] 151130.091550.8660: O365Integration:BackgroundTaskManager: BackgroundTaskManager.StopTasks called
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: Stopping UpdateDomainTask
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: updating UpdateDomainTask timer to: TimerSettings: DueTime=-00:00:00.0010000, Interval=00:00:00
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: Stopping UpdateSharepointAddressTask
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: updating UpdateSharepointAddressTask timer to: TimerSettings: DueTime=-00:00:00.0010000, Interval=00:00:00
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: Stopping UpdateO365IntegrationDataTask
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: updating UpdateO365IntegrationDataTask timer to: TimerSettings: DueTime=-00:00:00.0010000, Interval=00:00:00
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: Stopping UpdateCachedSkuInfoTask
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: updating UpdateCachedSkuInfoTask timer to: TimerSettings: DueTime=-00:00:00.0010000, Interval=00:00:00
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: Stopping UpdateMSOSecurityGroupDataTask
[34000] 151130.091550.8660: O365Integration:BackgroundTaskBase: updating UpdateMSOSecurityGroupDataTask timer to: TimerSettings: DueTime=-00:00:00.0010000, Interval=00:00:00
[34000] 151130.091611.9444: ProviderFramework: Critical: [100] : This exception (COMException) is crash-worthy, and will be treated as Unhandled. Operation details:
Service type: Microsoft.WindowsServerSolutions.O365Integration.O365ManagementProvider
Operation: [http://tempuri.org/] IO365Provider.Deactivate
Async: False
Parameters:
String id
[34000] 151130.091611.9444: ProviderFramework: Error: [0] : Unhandled Exception details: System.Runtime.InteropServices.COMException (0x8007203A): The server is not operational.
at System.DirectoryServices.DirectoryEntry.Bind(Boolean throwIfFail)
at System.DirectoryServices.DirectoryEntry.Bind()
at System.DirectoryServices.DirectoryEntry.get_AdsObject()
at System.DirectoryServices.PropertyValueCollection.PopulateList()
at System.DirectoryServices.PropertyValueCollection..ctor(DirectoryEntry entry, String propertyName)
at System.DirectoryServices.PropertyCollection.get_Item(String propertyName)
at Microsoft.WindowsServerSolutions.MailService.MailServiceADUtils.get_DomainName()
at Microsoft.WindowsServerSolutions.MailService.ActiveDirectoryHelper.SetLocalUserPrincipleName(String userName, String userPrincipalName)
at Microsoft.WindowsServerSolutions.O365Integration.O365ManagementCore.Deactivate()
at Microsoft.WindowsServerSolutions.O365Integration.O365ManagementProvider.<Deactivate>b__1e()
at Microsoft.WindowsServerSolutions.Common.ProviderFramework.ProviderBase`1.InvokeOperation[TResult](String operationName, Func`1 func)
at Microsoft.WindowsServerSolutions.O365Integration.O365ManagementProvider.InvokeOperationWrapperAsync[TResult](String operationName, Func`1 func)
at SyncInvokeDeactivate(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Microsoft.WindowsServerSolutions.Common.ProviderFramework.Internal.ExceptionScreener._ScreenForExceptions(GeneralInvoker invokeMe, Object instance, Object[] inputs, Object[]& outputs)
[34000] 151130.091611.9444: SharedServiceHost: Critical: [0] : _UnhandledExceptionHappened: SharedServiceHost.exe encountered an error (0x8007203a): System.Runtime.InteropServices.COMException (0x8007203A): The server is not operational.
