MotzTech
I'm having trouble with my personal gaming rig. Unfortunately I don't have spare parts to swap out to test everything, so I wanted to get some opinions.
When I first power the system on I don't get a video signal. No matter how long I let it run I don't get a signal. I have to forcefully power it off and back on several times before I get a video signal.
During the second or third power on I can hear what sounds like the fans slowing down and speeding back up. I have not been able to figure out which fan this is. Eventually one the third or fourth reset and power on, it boots up and everything works fine (or as fine as can be expected for 7 year old system).
I tested the RAM for an unrelated issue and it came back with a boatload of errors, but I tracked that down to what seems like a bad slot. Switching the ram so it did not use that slot fixed that issue. However I think this may be related.
I also tested all the hard drives, and they are fine. The issue occurs even if no hard drives are connected.
I installed a basic VGA video card to see if it output any type of signal when the main card didn't. It did not output anything. During gaming I don't see ANY performance issues with the card.
So I have narrowed it down to two things, a bad power supply or a bad motherboard. The power supply is a high wattage Antec,not something I keep around the shop.
The boot up issue makes me think motherboard, but everything works fine after it boots. Surely if the motherboard was going I would get all kinds of errors.
On the other hand, the fans slowing down like that make me think power supply. Which might explain why it boots up fine after it's be running for a bit and gets restarted.
What do you guys think? Sorry if I missed anything, been a long day but I wanted to submit this before I hit the hay.
