No display on a Toshiba Equium A300D-13X
Martyn
Bedfordshire UK
I've got a problem with the above laptop. It boots fine but with no LCD display. I have replaced the inverter and the display with no change. Initially it did display a faint image but with crackling from the screen(reported by the client). If I plug the old screen on another laptop it does crackle so that's finished I'm sure. Does anyone have a wiring diagram for the inverter input so I can test the voltages in or the pin to pin wiring to test the cable with a meter? Are the input cables from motherboard to inverter input standard between laptops?
You ordered the right inverter right?
Also, if you haven't, check the gpu for the hell of it.
edit:
and if you haven't check to see if it works with an external display
I would just try replacing the LCD cable
Yes I was having trouble finding a cable so wanted the pin outs to see if it was that. The old one looked fine but one came up on Ebay yesterday, got delivered today and worked.
Thanks, call closed. :)
