RetiredGuy1000
- St. Petersburg, FL
its only noticeably slower during backups when wireless. But when i connect with a wired Ethernet cable, its pretty quick.
Exactly. But my second 4TB drive comes in tomorrow and I will re-setup the NAS. AND I figured out where to look for the RAID settings. Seems if you arent paying attention, you can easily set a default setting that chooses Synology's version of RAID. But if you click 'custom' setup, then you can select RAID 1 for that. Looking forward to setting this up in RAID 1 for good tomorrow.Starting up with a 500 GB and 4 TB may limit the options shown. RAID 1 would not be an option in this case.
Good point - I hadn't thought of that!RAID 1 would not be an option in this case
I vaguely recall something similar, though I can't recall specifics. One thought I had is that if the 500GB is in the 1st position it might work, but if the larger drive is in the primary position it might not. It's pretty foggy back there so I could be way off.Maybe I'm thinking of another NAS solution but I seem to remember that specifying RAID 1 just makes the smaller drive the limit. So 3.5 TB would just be sitting there wasted.
Hows the speed on that NAS, synology use to have some really slow nas products that didn't have the processing power to handle max transfer speeds. I don't know what model I had tried in the past but I don't think it was that one.
^ This +1I just let them fail since they won't listen.
Given it's 1 GbE connection, there should be little issues with the speed of an individual drive being the bottleneck vice the ~113 MB/sec practical limit of 1 GbE...
Did you just post with the assumption that I don't know the speeds of a gigabit network? xD
The old budget synology nas products were extremely weak I don't recall the transfer speeds I got when I tested it but I want to say it was between 30-60MB/sec
Up until the point of post installation setup tasks and initramfs. God awful slow, even on my R810 64Gb ram. Dumped it after 20 odd minutes.Any of DIY-crowd play with Nethserver at all?
