Hi folks, I'm in a bit off a jam and about to blow a gasket. I upgraded a computer for client and now I'm getting repeated on/off cycle and I need help. Following is the scenario.
Re-used items:
- Case
- Video Card
- Wifi PCI card
- Sata hard drive
- Power supply
New parts:
- Gigabyte motherboard
- i5 CPU (stock heatsink)
- 8GB DDR3 memory
- PCIe firewire card
- 3.5 bay USB 3.0/card reader/eSata
Assembled everything, computer started fine and loaded into existing windows install without BSOD but needed drivers, then out of nowhere lost power and restarted, then power on/off cycle began every 5 to 10 seconds on, then off and repeat.
I removed PSU, video card (motherboard has built-in GPU) and then tried again. Immediately after powering on I got on/off cycle.
I replaced memory, same result.
I replaced the CPU, same result.
So I figured it was the motherboard, I got a replacement motherboard and immediately it was the same effect on replacement part. This is where I started banging my head.
I got a new (third) motherboard and did not hook up anything other than a fresh PSU. I didn't even hook up CPU and memory. Motherboard was assembled in the case and third board did the same thing.
At this point there's only one thing, the case. So I get a new Cooler Master case. Put barebones together and it works fine, loaded into windows and half an hour later the system power cycles.
I figured some old part (case?) might have contaminated the board diodes and capacitors??? (if there's such a theory)......
Now I've gotten fourth board.
Battle plan for tomorrow:
Install board in new case, use third fresh power supply, nothing else installed - not even CPU and let the board stay on for a few hours. If it stays on, then install one thing at a time with few hours runtime in between each part.
So far I have discarded and refuse to install all old parts from old computer including wifi card. To my surprise the client is agreeing to all this, obviously his bill has gone up dramatically.
Some things to consider:
Gigabyte H77M-D3H motherboard
Topower 500 watt PSU
Crucial DDR3 1300 (i believe)
Cooler Master case
i5 CPU
1TB WD Black HDD
Old 320gb sata HDD (can't remember brand)
Is there anything that I'm doing wrong? Did I mix up parts to kill other parts that in-turn are killing the new board? Is that even possible?
Help please, for my sanity. I've already lost money on this computer and that's fine but I just want this thing out of my store because time spent on it is affecting other jobs.
Help!
EDIT: Something to note, 3.5 inch bay powered on but didn't work when I plugged in a USB stick to it. Maybe it's a bad reader killing everything? Possible, but there were times when it was not installed with same results.... so I don't know whether to ignore this fact or not.
Re-used items:
- Case
- Video Card
- Wifi PCI card
- Sata hard drive
- Power supply
New parts:
- 8GB DDR3 memory
Cooler Master case
i5 CPU
1TB WD Black HDD
Help!
