MSI CoreCenter problem
Well, I just had the most interesting experience.
After installing one of MSI's diagnostic programs called CoreCenter for my motherboard, I was greeted with a BSOD as soon as I ran the program. After reseting, I was greeted by the BSOD again shorty after I logged in. The BSOD mentioned that I should check if I had enough hard drive space left. Being that I had barely 200MB left in my hard drive, I concluded that Windows was crashing because there wasn't enough room left on my hard drive to create a page file. (However, I don't have that much experience with page file problems)
So I proceed to boot UBCD4WIN to free up space on the C drive. Of course first I had to find UBCD and I didn't label the disc. So I ran around checking which CD it was on my floormate's computer only to find that none of the CDs I had were it. So I grabbed my hard drive and USB adapter and borrowed my floormate's computer again to burn the CD image. After deleting and moving files around, I managed to squeeze out 3GB of free space. However, I was once again greeted by the same BSOD after logging in.
Then it hit me. This all started when I installed CoreCenter and discovered that it was on my startup list. Not wanting to boot up UBCD again (it takes a lot of time), I booted Windows in safe mode and removed the program from my startup list. And behold, I'm back online again.
If anyone knows more about this problem, fill me in. I still have the program installed and can crash the computer on demand if I wish.
Have you searched the msi website for anwsers and what does the error say?
Is it this?
Application Failed to initiate properly (0xC0000135)
If so the answer is here:
When starts to run MSI Dual CoreCenter, the system gives an error message "Application Failed to initiate properly (0xC0000135)", how can I fix it?
Please install Dot Net Frame Work 2.0, as to use Dual Core Center must first install it.
NOTE: Taken from the MSI Knowledge base
http://www.msi.com.tw/program/service/faq/faq/esc_faq_search.php
Hope that helps! :-)
