One of my clients has a small office with a simple NAS setup. Two main folders on a Synology NAS and 4 computers. There's 4 users on the NAS having R/W access to these 2 folders, which are then mapped on the PCs.
PCs are not shared, so they authenticate to the NAS using the local users on Synology. There is no domain or AD in place.
The problem started recently. Everything was fine since approximately 5 years. They, more often than note, get the following error upon starting their computers in the morning and accessing the drives:
"Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again."
What I've tried so far:
- Remove any related saved credentials from Windows Credentials Manager
- Remap the drives using DNS name
- IPv6 turned off (just in case)
- Restart a few times, still worked.
The following day 2 computers had the same issue only to one of the mapped drives.
What I've tried following this (still unsure of the results):
- Remap one of the drives by IP, while the other was kept via DNS
Additional notes:
- I've given them a batch file to delete the drives and re-create them. This works without the need to restart.
- Stopping and starting the workstation service also works.
These are of course temporary workarounds and won't solve the issue. I wonder if anyone has encountered a similar problem. I have a feeling that this started since we've upgraded Windows to build 2004.
Additional notes:
