Hi,
I wondered if anyone has been in a similar position, in that I've used a couple of remote software packages in the past. These have both required me to open/forward ports on the local router to my work P.C in order to use the software. I recently moved offices and now have no access to the local router. I have no way of forwarding the correct ports to use my remote access software correctly. I've found Remotezilla, but that will require me to open ports on my home router to a local P.C and then forward the traffic from the home P.C. This sounds like it could introduce SLLLOOWW connections and response times.
I am looking for a reasonably priced solution.
I'm aware there are products out there that seem to cost $$1000.00's that will do the job and don't require port forwarding or router configuration. Has anyone found a reasonably priced solution for the average sole trader/single technician setup??
Thanks for any help.
Patch22
Patch22
