KM@ Dave
- Bournemouth, United Kingdom
Hi all, I've been developing for some time now, and have a few decent Programs out there but I'm stuck in loop for an ongoing bug fix. If you can solve this for me I can fix the bug.
Within my Program I'm calling from WMI, to view WMI references I'm using WMI Code Creator. Below is the code I'm using to call from WMI
And to view the final output I'm using a label and calling the Function name (Get_RAM_Test)
Now the thing is there's more than one stick of RAM and it only shows one stick. Because I'm new to using WMI I don't know how to sort this problem. The bug that occurs is when a LogMeIn mirror driver is installed it shows that, rather than the physical graphics hardware as it's reading from the first line of code in WMI, which is technically correct, but not the Graphics information I need.
Take the RAM for instance WMI Code Creator shows:
Capacity = 2147483648 <First RAM Module
Capacity = 2147483648 <Second RAM Module
My code only shows the 'First RAM Module', sorry for rambling on, I just needed to explain it as much as possible. How can I reference my code to show both the RAM Modules rather than only one.
Code:
Private Function Get_RAM_Test() As String
Dim zRAM = String.Empty
Try
Dim WmiSelect As New ManagementObjectSearcher _
("root\CIMV2", "SELECT * FROM Win32_PhysicalMemory")
For Each WmiResults As ManagementObject In WmiSelect.Get()
zRAM = WmiResults.GetPropertyValue("Capacity").ToString
If (Not String.IsNullOrEmpty(zRAM)) Then
Exit For
End If
Next
Catch err As ManagementException
MessageBox.Show(err.Message)
End Try
Return zRAM
End Function
