Yes, I meant the studying. ThanksThe actual test or the studying for it?
I believe the actual test is about 2-3 hours
How long the studying is going to take will depend enormously on how much you know about and have worked with Linux and whether your knowledge is as a user (how to use it), admin (how to make it operate) or developer (how it works so I can add things).
Some things you should understand answers to even if they're not actually asked:
- systemd or init.d, and why? (note: systemd is pretty much a done deal, but you still need to understand this)
- 'network' or NetworkManager? (same)
- what's in /etc/sysconfig/network-scripts and why might you care?
- vim or Emacs?
- separate /var partition? Other partitions?
NotedHow long the studying is going to take will depend enormously on how much you know about and have worked with Linux and whether your knowledge is as a user (how to use it), admin (how to make it operate) or developer (how it works so I can add things).
- vim or Emacs?
I will be reading and watching some YouTube videos. Thanks.Will wildly depend on you as a person. Will also depend on how you are studying. Will you be using books watching a video take a course?
Just because you can power through the textbook in a day doesn't mean you have learned it all.
As previously mentioned past experience will come into play here as well
then it will, but I'm willing to put in the work.Still depends on how fast you absorb information. If you have to watch the video twice to understand it your learning will take twice as long
