Appletax
- Northern Michigan
ideapad 3-14IIL05 Laptop - Type 81WD
Client sometimes sees this:
I only saw it twice. It's an intermittent issue.
Figured the iGPU is bad. The Lenovo diagnostics says it's fine, but maybe that does not matter:
Tested the RAM. Tested the SSD. Gave it a tune up.
Edit:
I moved the screen and it activated the weird artifacts.
Restarted and it went away, but the backlight is slightly flickering.
Edit 2: flickering went away and the screen is back to normal.
Edit 3: restarted and now the display stays black. Plugged it into an external monitor and it's not working.
Edit 4: back to working normal.
Edit:
